Hi all im new
Ive got a strange problem i hope someone may be able to point me in the right direction, for the last 6 month my thrust bearing on my alto has been whyning so i had last week booked off so thought il tackle it, i didnt skimp i bought a new bearing and new clutch too then it was only to do once, half a day goes by and the gearbox was off and clearly could see where the bearing had been rubbing on the clutch, i changed the bearing and fitted the clutch put it all back together and it was no better
the new bearing was rubbing on the new clutch, so its had a new clutch and new bearing it had to be a gearbox fault so went to the scrappy and picked up a gearbox, stripped the lot again so now has the new clutch, the new bearing in the 2nd gearbox and the new gearbox fitted, the thrust bearing is still pigging rubbing but no where near as bad but still does it when the clutch is out, im at my wits end
i cant think what else it could be.
Any suggestions would be appreciated.
Thanks in advance Phil.
