SWA Armour termination
12 Jul 2005
Bedfordshire
Hi all,
2.5mm^2 3 core swa terminating in a metal garage CU. Is it necessary to use the banjo on the gland with a flying earth to the earth bar (as well as the third core of the swa itself), or is the fact that the box is metal and the earth bar is attached to the box enough?
Also, what's the minimum allowed bend radius of 2.5 XLPE 3 core SWA?
Slip
17 Jan 2006
Kent
You should use the banjo with a 6mm bolt but I wouldn't bother to run a fly lead if the CU is metal.
Unless you are a body builder I wouldn't worry about the bend radius for SWA cables
8 Jul 2006
Yorkshire
just make sure the gland/locknut is tight. i always run a fly lead aswell-it bugs me if i dont!
going back to my padded cell now!
