Switched/Fused Connection Unit & Double Socket
31 Dec 2005
Suffolk
Pretty simple question I hope. I've just moved into a new flat and want to put a dishwasher in the kitchen, but need to add another socket for this.
There is a switched & fused conection unit above the counter that runs to a switched socket under the counter for the washer/dryer. If I replace the single socket on the spur with a double socket is this going to cuase any issues? Would it it be up to scratch?
I'm sure that adding a second spur would be the best options, but there are tiles above the counter where the current switch is located making it a difficult job.
Thanks in advance for the advice. As these appliances may run overnight I just want to be sure I'm going down the correct path.
14 Sep 2004
justbobet said:
There is a switched & fused conection unit above the counter that runs to a switched socket under the counter for the washer/dryer. If I replace the single socket with a double socket is this going to cuase any issues? Would it it be up to scratch?
itll be OK, since there will be a 13A fuse protecting the socket. BUT, if both appliances are used at the same time they could blow the 13A fuse.
JohnD
Do you accept rounds of applause?
15 Nov 2005
South
Cook Islands
You might want to change your fused spur for one with a neon, so you'll know when its fuse has blown (washer drier is quite heavy load, so is a dishwasher when heating, so this is very likely.
Meantime see how firmly attached those tiles are, and where the ring runs. What you are doing is protected by the fuse, but is not good design.
