C
Coniferman
I have this in the bathroom which is carpeted. (I know yuk, It needs a complete refit before long)
In the meantime, there has been rework in the past resulting in a cut/join between two pieces of the floorboards. (the big square ones)
It's not a huge problem but there is slight movement where the two pieces are not joined to each other, if I stand in the wrong place.
I know a proper fix, would probably be to cut out a hole and then fix a piece of wood underneath screwed to both pieces and then replace the cut out. The t&g goes under walls etc.
Is there some other quick fix that might work. The gap is only maybe 2mm so I don't know if some sort of glue would work or something else wedged in. Or some other fix?
