Tap connector issue
7 Feb 2010
I'm fitting some Bristan 1901 basin taps to a big old Royal Doulton sink. The ceramic is so thick where the taps fit, that once the nuts are in place under the taps, there isn't enough thread left to screw the tap connector fully home. Does anyone have a solution?
Richard
Thinking about it you probably still won't have enough space but is worth trying.
Maybe you'd get away with a brass socket (Toolstation 43908) and a hexagon nipple (63570)......it depends on how tight the tap is in the hole.
Of course, you could always invert the sink, and scoop out some of the ceramic with a stone disc in an angle grinder.
John :)
John :)
We're pretty much clear of the hole; it's just the thickness of the ceramic between tap and nut that is the issue. So much of the tail is used up that there's only a few mm left below the nut; enough to engage the tap connector but not enough to screw it home.
I thought maybe there might be an ultra-slim nut I could use.
Cheers
Richard
Use one of these with a 1/2 inch top hat washer then throw away the nut & olive
A 15mm x 1/2" female compression adaptor with the nut and olive discarded..........
..........otherwise known as a 1/2" tap extension, which most merchants will stock.
Excellent. And that will make a proper seal screwed to the the few threads I have available on the tap itself? Should I use PTFE?
Cheers
Richard
It's basically the same as what i showed you except screwfix don't sell it.You would be best to drop some fibre washers into the fitting so as when it screws up tight you have no gap and the end of the tap is tight against a washer if not ptf around the tap thread.
Thanks. However, this doesn't sound any different from what I could do with the tap connector itself ...
I'm obviously missing something here.
Cheers
Richard
Cheers
Richard
You are using this fitting as a COMBINED backnut and tap connector thus giving you a bit more thread :roll: :roll:
What i meant was that you can use this fitting as the backnut and then have a decent amount of thread for the tap connector.
Aha! Light dawns as the sun rises. Thank you very much indeed.
Cheers
Richard
