corgiman said:
not outlawed soft but they do not confirm to water regs as well you know
Lots of things don't confirm to Water Regs. The important point to note is that it is not neccesarily an item that does not conform to regs, but the way in which it is installed. An extending hose is perfectly acceptable providing the backflow prevention is of a standard suitable for the application and fluid risk that is present - in the home environement this would usally mean a double check valve.
[A good example of non-compliance in normal installation is garden hoses - they only comply with regs if fitted with a trigger device that cuts out when released...]
and the outside tap according the regs must not have a check valve within it but MUST be served by a double check valve located within the property
The taps with integral check valves are for use on existing installations (ie those that existed prior to current regs 1999).
New installations require service/isolation valve + double check valve within thermal envelope of a building.
