- Joined
- 14 Sep 2004
- Messages
- 15
- Reaction score
- 0
- Country
Some time ago, I needed the use of a telephone upstairs, so, being of the lazy persuasion, just ran an extension cable from an existing downstairs socket. The phone connected to this extension worked fine, except that it didn't ring, so I had to rely on hearing the phone ringing downstairs. When we got the place redecorated, the electrician ran the cable (presumably back to the master socket), installed a socket, and any phone connected to it worked fine - and even rang! Great.
However, I relocated the upstairs socket, and in doing so had to detach the cable from the socket. So I noted which wires went to which terminals, moved the socket and reconnected the cables as before. Result: no dialtone, nothing. The wires were connected as follows...
terminal two : white with blue bands
terminal three : white with green bands
terminal five : white with orange bands
(note that all three solid colours with white bands weren't connected at all).
Obviously I was somewhat confused that, in essence, just attaching and re-attaching the cables didn't result in a working phone, so I tried connecting cables as they *should* be:
terminal two : blue with white bands
terminal three : orange with white bands
terminal five : white with blue bands
Thus connected, I had a dialtone, wa-hey! Unfortunately I am now back to the position whereby any phone connected to this upstairs socket doesn't ring. Incidentally, the phone has a red light on it which hitherto has always flashed when the phone is ringing, or upon picking up/replacing the receiver. Now however it flashes only dimly when the phone is ringing, and is permanently on when the receiver is off the hook.
I just want my phone working and ringing as it should... any ideas?!!?!?! Many thanks in advance...
