Thermostatic shower mixer leak - cartridge?
8 Jan 2013
I have this thermostatic shower mixer but it doesn't have any branding on it.
Unfortunately it's leaking, a slow drip from the arrow on the left where I presume I would just need to get a new olive in there with some PTFE.
The bigger leak though is from the right hand side (in the picture I've removed the temperature control piece to get a better look)
After a shower if I turn the temperature to full cold then the leak isn't quite as bad as if it's left on a hot setting.
Am I looking at needing a new cartridge?
If I can't identify the brand I guess I'm looking at just having to replace the whole bar instead
Any views?
That's the way I was leaning towards,
It is a 150mm standard fitment, changing it over doesn't look too difficult so I'll see what we fancy changing to, possibly a Mira Coda Ev 2.
I have the same mixer bar which I need a new on/off handle cover for as mines threaded and won't grip any more. Does anyone have any idea of the brand or snowscreen if you change yours can I buy the on/off handle from you please?
Cheers guys
Dan
