Tiling Bathroom Floor
30 Apr 2007
I want to tile my bathroom floor. Is plywood suitable to lay onto the floor boards, then tile upon?
If so, what thickness plywood should be used?
Yes, most adhesive makers will say 15mm plus but if the existing boards are sound then 12mm usually works OK screwed at 200mm cts
Make sure it is WBP ply and use flexi adhesive & grout, look in the tiling forums for Gcols sticky and hundreads of posts on the subject.
JAson
If I lay 15mm plywood onto my existing floorboards and then tile on top, then there will be a significant height difference from my landing area which is carpeted to my bathroom floor. Is it not possible to use smaller thickness of plywood (say 3mm)?
Use 12mm and have a slight step - plenty of people do it. If you use 3mm your grout will crack and your tiles will almost certainly loosen. Alternatively, replace the floorboards with 25mm WBP ply and tile onto that.
Just a comment re the tiling.You really dont need ply to cover floorboards.Just screw floorboards every 6 inches to make them firm and use the adhesive made for tiling to the boards which is flexible and perfect for what you are needing in keeping height down.The fixing and grouting is with same stuff and not expensive,jus a few pence dearer.
give it a go,I have done my whole floor with it years ago and no probs
If I catch you spouting this nonsense on here again, I'll track you down and do to you what the little smilie on the right is doing below.
lol @ gcol
at your post ...lol
Jack bauer is sh*ting it , if he will have a job as the new bad boys on the scene ..lol..lol..lol..lol...lol....lol
