I have installed a fan, which is working, but isn't working how I want it to work.
I'll illustrate the wiring.
3 pole isolator switch outside bathroom. (3pisw).
Taken wiring from bathrrom rose. Neutral, switch live and earth. (there's no permanent live in the ceiling rose)
Taken live from light in the hall.
The fan works fine from the pull cord in the bathroom and comes on with the light in the hall being on, problem is, the light in the hall needs to be on for the fan to work.
I still want to use the permanent live in the hall, but would like the fan to work independent of the light in the hall.
There's no other permanent live anywhere else nearby.
Just to summarise...
switch live, neutral and earth going from ceiling rose in bathroom to the isolator switch.
Permanent live from light in the hall into isolator switch.
Then, permanent live, switch live and neutral to the fan.
Any help would be appreciated.
thanks
thanks
