Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I've just dry lined the downstairs loo, dot and dab, can anyone tell me will I need to have the wall skimmed before tilling or can I simply tile straight onto the plasterboard.
No need to skim the bits your going to tile & it will reduce the weight of tiles you can use if that's an issue. If only 1/2 tiling & wan't the rest plastered, get your spread to "waste" the plaster into the area around 50mm below the tile line, then tile.[/quote]
