We're recently changed our bathroom and had it tiled. The bath is in and works, and I've pulled out all the other stuff. The tiler came on Friday and did the floor, and plans to return next week to do two of the walls.
Today we tried putting the toilet in the room to see how it fits and ran into a couple of problems. Firstly, the old toilet was fed from the left (when sitting on the toilet) and the overflow was on the right. It was also an old design which did not fit flush to the wall.
The new toilet is designed to sit right up against the wall. This means that there is a large square opening through which the waste pipe can enter and the cistern sits on the toilet and is not connected to the wall. When put in place we realised the newly tiled floor raises the level of the toilet and the large metal waste pipe now clips the bottom of the opening.
In addition to this the feed pipe needs to be moved to the other side. As I can't put it under the floor without taking up the tiles again I intend to bury it in the wall. This I am happy with, but the waste pipe is a problem.
Does anyone have any suggestions. At the moment we're thinking either we need to somehow remove about half and cm of the toilet at the bottom of the opening to allow the waste pipe to clear it (no idea how. is there a tool?) OR buy a new toilet which does not have this problem OR leave the toilet sitting about an inch from the wall.
Any thoughts. Help most welcome. Thanks.
