The toilet was fitted about 5 years ago. Has worked fine till now!
Now after flushing, the toilet refills and the float arm rises, and closes the valve, but the water doesn't stop filling the cistern.
Its a bottom entry float valve with a small plastic float ( bought from Wickes)
Is it fixable? Does it mean I need to replace something in the valve like a diaphram?
Is this usuall to fail so early on?
I installed a second toilet about 3 years ago and that has failed to stop filling once as well ! but seems ok at the moment!
I'll tell you, I'm jinxed with plumbing in this house!
