Situation: Large-ish (1.5m x1m) double radiator on microbore takeoffs from 15mm main feeds in hall. Inlet/outlet are at base. Rest of heating system works OK.
Only the top half of the radiator is hot, and its heat output isn't really enough to cope with the weather we're getting just now. Definitely not air (which would in any case cause cold top, whereas this is the reverse)
Any suggestions?
Any suggestions?
