I posted earlier about a toilet I had overflowing. The problem was Identified as a torbeck valve problem.
So I replaced the valve with a 'Fluid master' one I had lying around, fixed great!
Just sorted out an air amittance problem on the newly fitted ( 2 days ago)downstairs loo ( nearly! )
Guess what?
In the midle of the night, the torbeck valve decides to keep filling, overflowing all night!
So I've turned the isolation valve to the cistern off untill I can sort it out.
and then
Flush the upstairs en-suite toilet and it doesn't stop filling- new toilet about 3 years ago with torbeck valve!
I did notice that the plumber who fitted the downstairs loo did fully open the stopcock. Where as it is only normally open 3/4 a turn. So I've closed that back down
All the torbecks have been fitted with the correct preassure reducing bits for use with high water preasure.
Are these valves prone to problems? I must sat they are all budget toilets and valves from Wickes. So do I just need a better quality valve?
I better break the news to hubby, we are down to one toilet again!
Guess what?
and then
