Is there a tool you can get to trim the bottom of wooden doors without taking them off the hinges. Mine are sticking and I don't want to go to the hassel of trying to get the screws out of the 150 year old hinges
A biscuit cutter will take at least 8mm off, which is probably too much. You can try a sheet of coarse sandpaper, hold it down flat on the floor and move the door back and forth over it. It takes a while but it works ok.
