did some work on a system with one of these today. Customer had fitted months ago, using 15mm plastic pipe. Run from pump too en suite was about 7mtrs. He said it worked fine at the start, but then started spluttering and getting cold later on.
Anyway he asked me to come along and tidy it up and make the pipework in copper.
so 22mm cold feed back to cold water tank.
22mm hot supply going back to a new surrey flange on the hot water tank.
all isolators on full bore valves.
only requirement from Triton was to have 15mm from tank to shower head which they have.
however, dreadful flow rate at shower and the pump only kicks in when the cold water on the mixer valve is on. if it is turned to hot it cuts out.
have to say that the flow rate with the pump switched off is dreadful.
can't even access the mixer valve at the shower as it is built in.
am i missing something?
