- Joined
- 19 Dec 2005
- Messages
- 101
- Reaction score
- 1
- Country
Merry Crimbo one and all. My kitchen tap is not behaving itself. Its a monobloc with swivel arm (don't know make) Fault one, when running either hot or cold some water seeps out from the swivel arm joint, is this easy to fix ? there is a small grub screw at the back of the tap which if I can find a small enough screwdriver and then get it to turn should presumably let me yank off the swivel arm, what am I likely to see is the trouble ?? and the second fault is that when running the hot only the tap doesn't flow properly, seems to jump and no water comes out until I turn it almost fully on, in other words there is no control over the water flow. Am I right in thinking that this is a fault with the inner mechanism (dirty/grungie) - if I take the tap top off and unscrew the thingymajig and lift it out (having first drained down the system) what fault am I likely to find, is this fixable or is it poss to just buy the replacement tap innerds. Thought about replacing the tap in total but having squinted underneath I would have one hell of a job getting the old tap off, and don't really want to take the kitchen sink and waste out. Any help would be appreciated, before you all get totally bladdered on your Xmas Babycham
