Type of wood i should use...
9 Jan 2004
Hey all.
I am creating an indoor/outdoor full growing suite for plants. here is my writeup of the aim if you want to read it, otherwise scroll down to my question:
Aim:
To create an environment where one or possibly more plants can be grown to their maximum potential, while requiring minimum manual maintenance. We will create an all-inclusive box that will provide correct temperature, water, air, CO2, nutrients and light leading to a near perfect crop because all of these things will be incorporated in appropriate ratios. We will be trying to accomplish this while keeping space requirements low and keeping costs to a minimal value.
The question I want to ask is what would be a good construction wood for this. It will most likely be buried outside, so i was thinking of getting standard MDF and then treating it with something (not sure what, any suggestions please). If not, what other materials are there (i know of marine ply-wood, but this is only a little project, 5' x 5' x 7', and i don't want to spend a lot on this wood)?
In advance, many thanks
jack
a55m0nk said:
Hey all.
Aim:
jack
unless the use of wood is prescribed I would use polycarbonate with sanitary quality silicone sealant or polythene sheet over wire hoops.
Both methods will allow an enclosed controllable environment to be created and maintained and neither will be susceptiblle to rot or decay.
Also as they can be washed out and even sterilised between crops they are reuseable, with improves the price performance ratio.
if you need to use wood, use marine ply with suitable varnish, unless you can get free cedar or black locust wood, both of which are naturally resistant to rot and insect damage.
If you wish to use preservative consider a boron based preservative prior to varnishing.
"Where treatment [of wood] is unavoidable, we suggest a boron-based treatment. Inorganic borate offers the least risk to human health, is a naturally occurring mineral, and has a long history of use." (Source, AECB Yearbook 1999)
from the text you supplied, your not trying to culivate some marajuana, are you!! :p
