UFH alteration
21 Aug 2022
I have had Ufh fitted in my house and recently had my boiler moved. I’ve been told that I now need two port valves, are these fitted to the boiler or the Ufh manifold and is it a big job for a fitter to do . All advice welcome
My valves are fitted to the pipework flow's I believe, one of the UFH (single room) one for the house. I have two thermostats.
Why only because the boiler's been moved do you now need valves?
They would only be needed if you want to zone the CH and UFH separately on their own stats or you have a cylinder too. If that's the case then it should have been done on install.
