Underfloor heating pump turns on central heating pump
8 Sep 2012
Middlesex
My wiring needs some changing but I don't know what to do. I installed new central heating and underfloor heating system; when one of the system turns on (UFH or CH), it turns the other system pump on as well(even though its off on the time clock); the trigger cable is all linked as the boiler only has 1 trigger so the power in the trigger is turning everything on directly even though the time clock is off. My master unit for UFH doesn't support central heating; the newer John Guest units support central heating which stops this trigger fault to turn on all systems however this is costly at £100. Are there any other solutions to stop the trigger turning on all systems?
Thanks!
Where can I get the relay from, any link? I tried to look for one before but I couldn't find any.
