uneven floor
26 Aug 2006
Surrey
HI
Hope you can help. I have a conservatory on the back of my kitchen.
The conservatory is 20 years old and has settled since first installed and now has a slight slop to the floor. It was like this when i moved in, and i have had people in who tell me that it will not move anymore.
The floor in tiled and when the kitchen meets the conseratory the joints have opened and the grouting has come loose. it does not help that the are heating pipes under the floor at this point. i keep re-grouting but its does not last more than a years before it needs doing again and some tiles in the kitchen are now cracked. I was thinking about laying a new floor but want to avoid this problem again.
In the kitchen the tiles are layed on a hardboard on top of floor boards. and the conservatory it seems they are layed on a solid floor. Do i take the tiles up, re-level the conservatory and if so what do i re-level the floor with, i assume also the skirting in the conservation would also need to come up and be re-fitted and then re-lay tiles, would it be best to put a ply base down before tiling. im open to what flooring is best, would some kind on flooring on a roll be better and solve the problem?
your thoughts would be appreciated
