UNEVEN WALLS
29 Jan 2007
Hampshire
I have just fitted a bath, however the walls are uneven, leaving a large V shaped gap at the tap end (20mm gap), has anyone got any advise on this one. many thanks
Gripfill a piece of board to underside of bath..........then later fill above with tile adhesive and run line of tiles horizontal from bath top to wall
I don't think builders have even heard of the terms 'Straight', 'Level', 'Plumb' or 'Right Angle' :rolleyes:
Did you chase the edges of the bath into the plaster? That might gain, say, 10mm or more. Once the tiles are fixed that will lose about another 6 - 8 mm, so your gap is down to a few millimetres.
Mind the gap behind the taps isnt reduced so you jam your fingers when turning them.
Otherwise, as Nige F says, fix a board or batten in the gap, and tile over it.
