I have a coax wire coming in through the window frame in my flat, and no roof access.
Is there an easy way to tell if its satellite or aerial? Pretty sure i can see both on the roof. I have only a normal analogue tv at the moment, and i don't want to buy the wrong box if i can avoid it.
I do have a multimeter and somewhere a cheap sat signal strength meter, but i understand this will indicate a freeview signal from an aerial also?
The wire is cut, no termination.
Dual shield, copper braid / silver colour foil with a foam core.
There is a splice half way up the outside of the building with what i think is connected with f connectors, its wrapped in tape but the shape looks familiar.
Not sure that helps with anyone's detective skills
Thanks in advance.
Thanks in advance.
