Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
This UPVC door is between my kitchen and garage. I want to use it eventually on my single brick garage external wall. Does it require a different sill? If so, what do I need to get?
Don't look like it has a cill just a low Ali threshold. You may find the door may catch on the floor once you have fitted it( depending on the floor levels) if this is the case just get a stub cill to put underneath the door, normally 30mm high
Will the threshold be fixed to the casing when I remove the full door/casing? If I get a stub cill, will the ali threshold sit on it or do I remove it.
Yes the ali threshold is part of the frame and yes it would sit on the new cill, God mentioned a stub cill but they're only 85mm deep and would offer no overhang on any brickwork, much better to use a 150mm cill, bear in mind though that sitting the existing frame on a cill will of course make the overall height ot the frame 30mm taller
