recently the front door has begun jamming. I notice it's a lot worse on cold mornings. It's upvc so should not be expanding as it and the frame are not made from wood. All the edges are plastic, but there is a block of metal in the bottom corner of the frame and I think this is what's causing the door to stick. The small metal piece is about 3cm square with a few screws in it. Are these adjustable? what can I do to adjust the door? (obviously I can't get a plane onto it, as I could have done with a wooden door.) The door was removed last year to get a large piece of furniture in. I think there were a few allen key bolts on the hinges and they were removed and then put back. Could that have changed the alignment of the door? If so should I try to adjust the door from there?
thanks.
thanks.
