uPVC or Composite Doors
22 Mar 2008
Hi Guys,
Given the choice of a uPVC or a Composite door which is best.
Regards,
Bill
Not fond of either but composite ones look a heck of a lot better.
the solid hardwood one of course
why are you restricting yourself?
Interesting post....
I assumed, perhaps wrongly, that uPVC doors were better as they generally reduce draughts.
Composite doors, I assumed, had the beneits of the uPVC in terms of reduced draughts, but, as already mentioned, look a lot better.
yes, a plastic door will keep the draughts out
but not the burglar.
the locking mechanism will also go wrong a hundred times more often than the lock on a wooden door, and be a hundred times more difficult and expensive to have repaired.
It will also be more expensive than a better hardwood door.
No contest IMO
Have a browse through http://www.diynot.com/forums/viewforum.php?f=18 and see if you can detect a pattern.
draught extruder.
The silicone rubber P-strips or E-strips are very good.
If you buy a new door frame as well it should come with a weatherstrip that goes into a slot round the frame.
If the frame and door are very old they might be warped or loose and you can address this.
If you do want a door curtain, get a Portiere Rod which pivots up and away when you open the door.
