Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I've used Adkwik in the past. Airpress and Glued Direct can also supply UF glues. You will need to wear a close fitting dust mask whilst mixing the glue from powder
Are you aware that UF glue joints need to be bonded under pressure, so you will need quite a few sash cramps and home made cauls to do the job? The other thing is that technically, under current regs, relipping a fire door yourself voids the fire rating certification of the door (something we are now told repeatedly in the aftermath of Grenfell). I am surprised nobody mentioned that on a fire safety forum
