    Dismiss Notice
Useful Tool
Discussion in 'Tools and Materials' started by Teddy, 6 May 2004.
  1. Teddy
    Teddy
    29 Apr 2004
    5
    Thanks Received:
    Country:
    I bought a "Drain Easy" Device, made by Drayton, which is designed to allow one to change Heating valves, pumps, radiators, etc., without draining down the system and losing your Inhibitor.
    Working on the basis that the inhibitor costs over 10 quid this tool pays for itself (also around 10 quid in B&Q) at the first attempt.
    It consists of two tapered rubber plugs connected by string. You put one plug in the expansion tank outlet hole and the other in the overflow pipe over the same expansion tank. It will fit 15 & 22mm.
    After that you can (and I have ) take out the pump/TRV/etc with less than a teaspoon full of drip. I just used it to change the 3 way valve here.
    You have to remember to remove the device before firing your boiler up (wonder why!!!)
    Also you need to check for air locks after use!
    Pretty fine tool though..Can't recommend it highly enough.
    By the way, I have no connection with anyone in the manufacturing or selling of any product...I'm a retired old duffer.
  2. Sponsored Links
  3. masona
    masona
    5 Jan 2003
    12,885
    Thanks Received:
    125
    Essex
    Country:
    Interesting but what happen if the plug come undone or can it not ?
    I take it this work by suction ?
    Any plumber out there, any comments on this ?
  4. AlanE
    AlanE
    26 Feb 2004
    2,986
    Thanks Received:
    557
    Essex
    Country:
    Been using a set for ages.
    Alan
  5. peter anderson
    peter anderson
    28 Feb 2004
    179
    Thanks Received:
    Country:
    why do you need a plug in the overflow pipe?
  6. Sponsored Links
  7. oilman
    oilman
    16 Sep 2003
    7,978
    Thanks Received:
    30
    Country:
    Terminology, should have been vent pipe, not overflow.
  8. masona
    masona
    5 Jan 2003
    12,885
    Thanks Received:
    125
    Essex
    Country:
    Is it possible to use gate or ball valve instead of plug ?
  9. Teddy
    Teddy
    29 Apr 2004
    5
    Thanks Received:
    Country:
    I's a bit of physics. e.g if you stick a bung in the end of a length of copper tube, then fill the tube with water, you can then turn the tube upside down and the water will not run out.
  10. ChrisR
    ChrisR
    24 Jul 2003
    23,957
    Thanks Received:
    1,327
    London
    Country:
    You can use a speeedfit cap on the end of the vent pipe, and a ball of plumbers mait in the header tank. I found my cones often wouldn't work in the header tank because of tank connectors with internal ridges for turning with, which some have.
    Lucky to have it work ona 3 port, I'd have thought, because there's a circuit open at both ends - why shouldn't the water pour out?
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
