Recently had some rads off to decorate and changed a few valves etc.
When the pump overun finishes there is a click noise which is heard.
It doesn't come from inside the boiler eg a switching noise, but seems to come from the pipes themselves. The pump has started to sound a bit ruff lately, like its bearings need an oil, how easy are these to replace. Its only 18months old though.
Also has anyone had problems with the aqua sensor rattling?
Mine rattles when pressure is on full.
Pressure isn't really high though which confuses me. Just turning the pressure down a bit is enough to calm the rattle.
I forgot to mention that when heating is not called for anymore the actual boiler makes a loud bump. Similar to the type of bump when the gas is lit and it has built up before ignition.
