Vaillant hot and cold shower
31 Dec 2014
Hi wonder if anyone gave give me some direction with this ... my central heating is fine, but in the shower (mixer taps) the water is hot for a minute or so, but then runs cool (but not cold). If I turn the hot water off, wait a few seconds then turn it back on the water flows cold for a time (as you would expect) and then the hot water flows as it should (reasonably hot). Would appreciate help! Thanks.
Does the water run hot and constant at the other taps?
If the mixer isn't thermostatic then it's always going to be a bit erratic.
Thanks James. Yes downstairs the water runs hot without cooling at all. Upstairs I can't run a bath full of hot water. Both come from the same source!
I hadn't considered a thermostatic mixer..
