hi guys
only done it once at college and need a quick recap on checking valve clearances with cam covers
I know how to do valve clearances with the adjustable nut on straight forward valves and as far as a ican recall the cam covers are thickness of the valve clearance
so is it a case of take out the cam covers check clearance then replace cam covers to the correct thicknes or do I simply use feeler gauge between cam cover and camshaft/rocker
as I say only dun it once so a little help would be appreciated
terry
terry
