Varnishing stair treads and risers
20 Aug 2006
West Glamorgan
Have moved into a new property (1960 build). the stairs are in good condition. Currently have carpet runner on, which I want to get rid off and varnish the treads and risers. Would like a low sheen varnish finish, which would be better matt or satinwood? I'll be putting sisal stair mats on the treads so slipping shouldn't be an issue. Also tips on technique would be helpful
thanks rob
If your carpeting the treads why do you want to varnish them?
Neither of the varnishes you mentioned are particulary durable when it comes to feet etc you may need to think about diamond glaze or bourne seal
well the tread mats i have in mind do not cover the whole tread so the bare areas will need some protective layer. Take the point about diamond seal - thought of using that for the floorboards upstairs which are in good condition.
Bear in mind though...water based varnishes wont darken the wood and bring out the colour as much as oil based
When you do it varnish every other tread first or of your covering them up anyway...just varnish half of each stir...that way youl still be able to go up and down the stairs.
robdec said:
thanks for the tip zampa - the mats are semi circular so do i need to do anything extra?
I wouldnt have thought so..just make sure you fix em down well
Where in W/Glam?..thats where I work
