Vinyl Floor Adhesive?
24 Nov 2009
West Glamorgan
Hi all i want to fit some vinyl lino the Roll type. I will be fitting it to concrete, what adhesive is best to use? ive never layed this stuff before.
thanks in advance
If you are laying sheet vinyl, you should'nt need much adhesive as it is designed to be loose laid, if you decide to stick two adjacent sides, you will need anti-plas tape, a special double sided tape that won't allow the adhesive to bleed through the vinyl.
If you are considering fitting sheet linoleum, I would'nt recommend it unless you have some one with you who does know what they are doing, the extra floor prep and laying technique is a completely different ball game to sheet vinyl.
