Vokera Combi Boiler - Help!!
6 Feb 2005
I have a Vokera Linea 24 combination boiler. There is a constant sound in the house like water is running and the tank is constantly filling. The radiators sound like there is water running through them all the time, even when I turn them off at the valves on each one. This problem started a couple of weeks ago and happens all the time, the noise continues day & night. I have not changed anything recently. The pressure in the boiler drops all the time and I need to top it up. This has always happened since it was installed 6 years ago. It's been looked at several times, but I was told it could be a tiny leak anywhere in the pipes under the floors and we would probably never find it. The pressure drops more quickly now though and I need to top it up every couple of days. When I turn boiler to hot water only, the noise stops. Thanks for any advice you can give.
If its not sorted out soon then you are going to have serious difficulties and will have to have it power flushed ( cost about £300 ).
Are some rads cold at the top?
Have you felt all the rad valves for wetness and checked the relief valve vent outside? Maybe tie a bottle over the end?
Tony
