boiler is firing for between 20 and 30 seconds then then cuts out. water runs cool before boiler fires up again. This process is repeated. The dhw water runs very, very hot, regardless of adjusting the hot water manual dial on the face of the boiler. central heating working fine.
Diagnostic in installation and servicing manual states that this problem may occur for the following reasons.
hot and cold water pipes crossed
cold water regulator valve needs to be opened more
regulator valve may be blocked and needs cleaning
I have double checked the pipes tracing both hot water from the boiler and cold water from meter before re-routing pipework and installing the bathroom suite and shower mixer valve. I checked again when the problem with the hot water supply became apparent. All changes to pipework that I have installed were beyond the "T" where the cw feed branches to bathroom and kitchen. All new pipework immediately beyond this "T" was fitted with a ballfix valve on the branch serving the bathroom (similarly with the dhw) which I fitted first so that the cw and dhw could be reinstated for the kitchen whilst I worked on the bathroom. So any debris could not have ingressed to the boiler. All feeds to the cw and dhw drain off points have been traced and there is no crossed cw/dhw pipes.
Upon inspection the cold water reg valve was barely open. So it was opened fully and flow/delivery of dhw checked again... problem persisted, dhw flow rate seems low.
Regulator valve was removed and checked for blockage or damage to the jumper on the valve. Valve working ok and no blockages were encountered on the inlet filter. Delivery of cw was tested whilst the valve was off. Pressure test guage read 4.2 bar.
The pressure of the dhw at the drain off points is still very low, however which suggests a problem with the boiler.
From my limited experience, and this is purely speculative, the problem may be:
a blockage inside the boler???
a faulty diverter valve???
an electrical fault dhw thermistor which is perhaps unlikely as the hot water, when it does heat, is very, very hot so the thermistor may be causing the boiler to turn off the hot water as a precautionary measure to prevent scalding for example.
I would be intrigued to know what the likely problem is.
