Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
It's quite a difficult one, you take the front portion of manifold off (after undoing it's attachments) New large diaphragm doesn't always fit good or seal good even though supplied by Vokera. Wrong gland for the front manifold which you took off usually supplied by vokera, there must have been variations in the past, and the kit they now supply doesn't quite work. You do get a little o ring though which is nice.
You're advised to do the smaller primary flow sensing diaphragm and bits and pieces over on the left of the boiler also.
