Hi can any one help please.
I have a vokera 80sp excel 9 years old. Been serviced by B gas every year. No longer on contract.
The timer comes in at 6AM boiler fires heat up C/ heating rads fine. Then 15 minutes or so later burner goes off but pump keeps pumping hot water around rads.If you turn hot tap on during this period it will not fire.
The diaphragms and both micro switches replaced.
Also replaced the 7311(UPPER LIMIT THERMOSTAT OR INTRUPTER) as someone suggested.
Still no hot water. If I wait until boiler cools down a few minutes later it will fire and hot water is fine.
This only happens at morning.
I am an electrician so if you have any suggestion regarding checking voltages please fire away, any comment appreciated.
Regards,
Alex
Regards,
Alex
