I currently have a vokera excel 80sp combi boiler.Just recently the boiler has started to bang and boil the water in the heat exchanger.The boiler is 7 years old.The safety stat is working and shutting down the burners.It does this both with the hot water tap and central heating.What also occurs is that the central heating pressure is affected when the hot water tap is turned on.Dropping the pressure down to 0.5 bar but returns to normal working pressure when the tap is turned off,Any ideas would be greatly appreciated.
