vokera Mynute and Y plan wiring
23 Oct 2005
Leeds
Hi Chaps, anyone installed a new Mynute HE on to an existing Y plan system that has the honeywell sundial y plan wiring centre installed ?
Just trying to figure out the correct way to wire the boiler as this configuration supplies 240v to the boiler via the wiring centre on a call to heating or hot water. This is ok but the boiler requires a permanent live (i presume to control pump overrun)
I know vokera supply dual channel programmers that fit to the boiler but the customer wants to keep his original controls.
Any help would be appreciated !
Thanks for the reply EliteHeat.
Done a little more looking and what Vokera dont tell you is how to wire the switched live from the Wiring Centre. They only show wiring diagrams using the vokera programmer.
From what I can gather now is the switched live should be connected to the 3rd terminal on block m5 in the boiler and the link removed.
If you've had any experience of this set up it would be good to hear. I'm going to give this a go anyway to see what happens !
Haven't done it before on this boiler and my mynute manual may be old, but it seems that terminal one is the permanent live from the boiler terminal strip and is used to power the programmer and terminal 2 is the switched live from the wiring centre.
The rest appears as normal.
