I am installing a shower tray. The waste will run into the waste pipe from the sink, but the central heating pipes run across where I need to run the waste pipe from the shower tray. Do I need to reroute the central heating pipes under the waste pipe, or can I put a shallow 'u' type trap in the waste pipe run to go under the central heating pipes. Also, the shower tray waste run is 5 feet to the sink waste pipe. What is the minimum drop I can get away with when running the shower tray waste pipe, as I want to avoid building a plinth if possible.
