Water does not heatup, radiators seem fine
12 Aug 2007
Edinburgh
Hi
In the last few days my hot water has not been heating up. I have checked the boiler pressure and bled the radiators and although the radiators heat up fine, when I try to heat the water without heating the radiators - the water does not get hot.
I have noticed that when I switch the water on, it sounds like the boiler starts but approx 20 secs later it stops again
Any help will be much appreciated
Which boiler are we talking about here, If you can tell us make and model im sure someone on here will be able to help. Regards chrisey
Hi
The boiler is an Ideal Classic and the water tank is a Tribune Premiere, model number TP150B.
Yes Dan seems like the valve, unless there is two pumps on the system!!
cheers chrisey
