Hi I have a Worcester 24i RSF-L It's been loosing pressure through the PRV and the last few days I've also noticed a pool of water under the boiler. On removing the boilers front cover then opening the metal cover (held in place by four screws) I noticed to the right of the heat exchanger a brass type valve? bearing the number 4301 with a small internal threaded hole on top water from the cistern is leaking from this. Does any of you guys know what this is and it's not linked in any way to the gas or electrics of the boiler is it easy to replace? I'll replace the PRV as a precaution
Many Thanks for reading this rather long essay
