Water Pipes
11 Feb 2007
i have to re route the hot and cold pipes to a new sink position. i can see where i turn the cold off but where do i cut the hot supply. Is it by the combi boiler?
Please help
________________________________
Lynda, moderator
You can post in other forums too, not just Floors etc.
Post has been moved
If it's a combi boiler, turning the cold water feed to it off will also turn off your hot water. If you're refering to an isolating valve just under the tap then you'll need to go to your combi and turn off the main cold water supply to it.
