Water Pressure Worcester 28cdi
28 Jan 2007
Cheshire
When using hot water which is heated by a Worcester 28cdi combi boiler and you switch the cold water tap on the hot goes off, this is worse upstairs, but downstairs the hot shrinks to a trickle. With just cold on there is a good pressure any help would be appreciated.
Are you at the top of a hill, or top of a block of flats?
Do you know what your incoming water pressure and flow rate is?
Do you have a check valve, and/or a filter, on the incoming cold mains?
Has it always been like this?
Is a corner terrace house in a close, the water pressure at the downstairs tap is fairly powerful with only cold on.
