Could some one please confirm or recommend.............
is it ok to fit service valves / washing machine taps just after the main stopcock (/check valve) going into the property - or should they be full bore , since I need to connect up the water softener, of which all the water in the property, bar the drinking water, will pass through. Could this cause any problems due to the restricted bore these valves present?
(Heating system is indirect), cheers
