    Dismiss Notice
Water Softener - White 'Stuff' in brine tank
Discussion in 'General DIY' started by letmedoit, 3 Apr 2018.
  1. letmedoit
    letmedoit
    4 Jan 2011
    59
    Thanks Received:
    Norfolk
    Country:
    We have had water softeners for over 25 years (Norfolk has very hard water). Current model has worked fine for a long time but last year got some sort of contamination in the brine tank. This appeared as little white specs which got worse untill it blocked the gauze filter in the brine tube. The brine eventually looked like it had some dissolved tissue paper floating in it ? I removed the brine and salt and washed out the brine tank, refilling it with clean salt from a new bag.
    The machine has worked correctly since until this week when it all happened again ! I have cleaned everything out, put in fresh salt from a new bag and all now seems fine. It never happened previously so what is this contamination and how do I prevent it happening again ?
    Apart from using bags of Hydrosoft granular salt the only other thing put in the machine (last December) was some Water Softener Resin Restorer bought from Wrekin.
  2. Sponsored Links
  3. foxhole
    foxhole
    14 Mar 2006
    17,993
    Thanks Received:
    2,064
    Kent
    Country:
    Maybe try plumbing forum?
  4. letmedoit
    letmedoit
    4 Jan 2011
    59
    Thanks Received:
    Norfolk
    Country:
    Thanks, I did check that forum but couldn't see anything about water softeners. Now I have done a more thorough search I can see that is where they have been posted before. I will re-post this in the plumbing section and hopefully get some answers there.
    Mods. Please feel free to delete this thread to prevent duplication.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
