A lot of us are familiar with the good old safeblock, as used to make temporary electrical connections to equipment under test.
We use these a lot at work for testing of newly made kit (it isn't sensible to fit a 13A plug because the kit often isn't destined for the UK). This is fine & dandy for equipment which I tested on clean, dry bench.....
Some of our products use water as part of the experiment that they do.... I have noticed that it is often the case that these are still supplied using a safeblock & hence the safeblock may become sprayed with water if the test fails!
Does anybody know of any 'waterproof' safeblocks or something similar which is better than IP00 ???
Adrian
Adrian
