WB 240 Pressure Vessel Replacement
30 May 2006
Leicestershire
I have a Worcester Bosch 240 which with the help of you guys replaced the diverter parts many times etc etc.
The pressure is above 3Bar and I have replaced the PRV.
Water is passing out of the charged 10ltr Pressure vessel so it needs replacing.
But as Im a cheap skate and seen Rogue Traders ETC Im thinking about fitting a new one, the manual says I need to remove the Gas Valve.
I ant doing that. what about fitting a 12ltr remote expansion vessel as my boiler is in the Loft I can fit it near to the boiler mounted on a wooden floor.
Can I do that or would the old EV need to come out because of another reason.?????...
