We Steel beam install first floor
23 Jan 2023
Hi all,
Fitted a few steel beams before on ground level but not on first floor..
How do I setup acros on the first floor? Do I install them sitting on the floor joists with a board running across the bottom?
Do I need to setup across on the ground floor as well? Directly under the acros on 1st floor. The ground floor is a suspended timber floor.
What size timber should I be using for the header on acros?
Many Thanks
Hi all,
Many Thanks
Yes, use a spreader board across the joists.
